cancel
Showing results for
Search instead for
Did you mean:
Create Post
Node Custom Properties uses report
I have been using this report for some time to identify what the potential impacts of making changes to a custom property are.
It looks through all the properties, then checks them against the following common use cases
Alert trigger/reset conditions
alert actions
group definitions
account/view limitations
views
resources/widgets
reports
Just import the xml file in as a report and you will be all set. It can be slow to load in some environments.
-Marc Netterfield
Comments
Perfect timing! I was just reviewing stale CP's and your report came in handy! Good work!
Give mesverrum​ a Nobel prize for this one!
Oh, and please bake this into the product.
What a superb report. Thank you so much.
Awesome report. Just what I was looking for. Thanks a lot.
Found this just when i needed it. Thanks Marc. 😄
Is there an easy way to modify this for custom interface properties?
Version history
Revision #:
1 of 1
Last update:
‎05-22-2019 05:16 PM
Updated by:
