SQL Query - Add Interface Configured Bandwidth
Need to let the other teams know the configured bandwidth of interfaces to stop us being queried each time.
Having some issues with our SW product due to be upgraded next month to resolve so kind of stuck me without being able to query our SQL DB to see what the entry I need is. Also I'm complete novice at SQL and someone made the below previously. Anyone able to help add configured bandwidth into the below?
SELECT DISTINCT
	PSCView.Node,
	PSCView.Location,
	PSCView.Inbps,
	PSCView.IfName,
	PSCView.InterfaceAlias,
        PSCView.Internal_Location_ID,
	PSCView.Outbps,
        PSCView.PollInterval,
	PSCView.Status,
	PSCView.StatusLED,
	REPLACE(PSCView.StatusLED, '.gif', '') AS StatusWord,
	PSCView.Caption,
	PSCView.IfSort,
	--CONCAT (PSCView.IfName, ' - ',PSCView.InterfaceAlias) AS NewInterface,
	PSCView.DetailsURL
from (
	SELECT
		Nodes.Caption AS Node,
		Nodes.Location,
                NodesCustomProperties.Internal_Location_ID,
		Interfaces.Inbps,
		Interfaces.IfName,
		Interfaces.InterfaceAlias,
		Interfaces.Outbps,
                Interfaces.PollInterval,
		Interfaces.Status,
		Interfaces.StatusLED,
		Interfaces.Caption,
		REPLACE(REPLACE(REPLACE(REPLACE(REPLACE(REPLACE(REPLACE(REPLACE(REPLACE(Interfaces.IfName + 'AAAAAAAAAA','/1AAAAAAAAAA','/01AAAAAAAAAA'),'/2AAAAAAAAAA','/02AAAAAAAAAA'),'/3AAAAAAAAAA','/03AAAAAAAAAA'),'/4AAAAAAAAAA','/04AAAAAAAAAA'),'/5AAAAAAAAAA','/05AAAAAAAAAA'),'/6AAAAAAAAAA','/06AAAAAAAAAA'),'/7AAAAAAAAAA','/07AAAAAAAAAA'),'/8AAAAAAAAAA','/08AAAAAAAAAA'),'/9AAAAAAAAAA','/09AAAAAAAAAA') AS IfSort,
		'http://ixnetmon.ptv.com/Orion/Interfaces/InterfaceDetails.aspx?ViewID=229&NetObject=I:'+CAST(Interfaces.InterfaceID as varchar(256)) as 'DetailsURL'
	FROM
		Nodes
	INNER JOIN
		Interfaces ON (Nodes.NodeID = Interfaces.NodeID)
         INNER JOIN
		 NodesCustomProperties ON Nodes.NodeID = NodesCustomProperties.NodeID
	WHERE
		Nodes.Caption LIKE 'GBLEE2O-SW%'
) PSCView
ORDER BY PSCView.Node, PSCView.IfSort;
  • If you have configured a custom bandwith [dbo].[Interfaces].[CustomBandwidth] will be =1 and [InBandwidth]
     and [OutBandwidth] will have the values you configured.
    So I would just have a column that states if the bandwith was customized or not, and maybe also the bandwidth on all interfaces.
  • Maybe you can go with this:
    SELECT
    	Nodes.Caption,
    	Nodes.IP_Address,
    	Interfaces.FullName,
    	Interfaces.InterfaceName,
    	Interfaces.InterfaceTypeDescription,
    	Interfaces.InterfaceSpeed,
    	Interfaces.InBandwidth,
    	Interfaces.OutBandwidth,
    	Interfaces.Caption,
    	Interfaces.IfName
    FROM [dbo].[Interfaces]
    	INNER JOIN [dbo].[Nodes]
    	ON [dbo].[Interfaces].[NodeID] = [dbo].[Nodes].[NodeID]
    WHERE Nodes.Caption LIKE '%'
    ORDER BY Nodes.Caption ASC
    You can replace the WHERE Nodes.Caption LIKE '%' Statement with the Node name, LIKE '%Switch1%'
  • I don't use SQL for my reports, but use SWQL instead.  I think what you're looking for would be under Orion.NMP.Interfaces under Speed.  If I'm understanding your question, you're looking for what the devices currently have configured for bandwidth, not what is configured manually in the interface details page.
  • The Current Interface Bandwidth report should contain everything you need.  If not, it's a good starting place for crafting your own report.
