These instructions didn't work.
This article provides steps to create a report that lists installed software on each Node.
Environment
SAM version 6 or later
Steps
Note: This article assumes that the Asset Inventory option has already been enabled within each Node's List Resources feature.
1. Log in to the Orion Web interface.
2. Click Settings > Manage Reports.
3. Click Create New Report.
4. Select Custom Table, and then click Select and Continue.
5. Set I want to report on to Node and add any conditions to isolate report down to specific Nodes.
6. Give the Selection Name a unique name. For example, All Workstations.
7. Click Add to Layout.
8. Click Add column.
9. Scroll down in the left-hand pane and click Software Inventory.
10. Select all columns and click Add Column.
11. Click the green + to add another column.
12. Select Node Name and click Add Column.
13. Set the Group results by to Node Name - Node.
14. Click Submit.
15. Proceed through the remainder of the Add Report wizard giving the report a name and such.
Once this is complete, you should now have a report that provides software inventory for each Node.
