cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Customize View and Resource Problem on NetFlow conversations
Hi all,
I create a customize view for us for Network troubleshooting.
I used "Custom Object Resource" for health check the conversations on one of our core switch.
However, the object resource can only show the endpoint centric of the targeted source.
I want to create a "top xx conversations" which can show the conversation between One NetFlow source.
Is that possible for this design?
Also, can I customize a dedicated resource for my customize View.
Thank you for your helping.
0 Kudos
