cancel
Showing results for
Search instead for
Did you mean:
Update SecureCRT using SW
Hello All,
         I looked around and didn't see a similar solution posted so I figured I would put mine here. This is a python script that can be run to pull all of your Cisco devices out of Solarwinds and create an XML document that can be imported into Securecrt to list all the names and IPs of your devices. It sorts them by a Region folder, then a Site folder based on the region and site custom property. It can be tweaked for your environment. I hope this helps others.
Thank you,
JAF
Comments
I get an error. This is line 3 in the code No module named 'swisclient'
Version history
Revision #:
1 of 1
Last update:
‎03-13-2018 02:56 PM
Updated by:
