cancel
Showing results for
Search instead for
Did you mean:
Create Post
Orion SWIS Schema Documentation Updated for 2020.2
Now that Orion Platform 2020.2 and its modules are generally available (see this announcement for details), the SWIS Schema documentation has also been updated.  You can now see documentation of the API for the past four releases (2018.4, 2019.2, 2019.4, and 2020.2).  Select the version that matches your environment and read the docs here: http://solarwinds.github.io/OrionSDK/
Labels (1)
Comments
Are you able to share documentation that describes the deltas between schema versions?
Similar to Release Notes for SolarWinds products. I'm trying to figure out if the SWQL I have written will break when I upgrade. I know the database schema changes between versions, and that's one of the reasons I moved from queries using SQL to SWQL, to hopefully avoid too much rewriting. I'm constantly leveraging SWQL thank you for providing it.
Version history
Revision #:
2 of 2
Last update:
‎06-04-2020 03:10 PM
Updated by:
