cancel
Showing results for
Search instead for
Did you mean:
Create Post
Import Node and custom properties
Hello,
Using Orion SDk, can I do following at the same time
  (1)Node(IP, Caption and so on.) register (There are overlap IP Address)
  (2)Custom properties values assign for DateTime type
About (2), there are some custom properties of DateTime type.
Can I import value for custom properties of DateTime type using Orion SDK ?
Would you please provide samples if you have them for above
KH
Version history
Revision #:
1 of 1
Last update:
‎02-18-2019 10:25 PM
Updated by:
