cancel
Showing results for
Search instead for
Did you mean:
Full Orion alert rule export using Powershell and OrionSDK
Orion does not yet have a way to perform a complete bulk export (full backup) of all alert rules from the web console UI.
So as of today, the only option is to use the OrionSDK.
There are several use cases on why an Orion admin might need to perform a complete alert rule export.
1. When migrating from one Orion instance to another.
2. Alert rule synchronization between multiple Orion instances.
3. Backup.
Provided below is a Windows Powershell script that will export every ENABLED alert rule from an Orion instance.
Each alert rule will be exported to individual XML files using the <ALERT NAME>-ID-<ALERT ID>.xml naming convention.
# --- ORION-ALERT-BACKUP.ps1
# --- Author: Joseph Dissmeyer, www.dissmeyer.com
# --- Last updated: 2020-01-15
# --- Reference: https://thwack.solarwinds.com/message/433199#433199
# --- Save as .ps1 file in your scripts directory.
# --- How it works:
# --- Downloads all enabled alert rules from an Orion instance.
# --- Each rule is saved individually as .XML file to the same directory
# --- where the script is executed from.
# --- NOTE: This only exports alert rules that are currently ENABLED.
# Requirements:
# 1. OrionSDK. Download binaries from https://github.com/solarwinds/OrionSDK
# 2. An Orion basic user that has "Alert management rights" enabled.
# 3. Edit the hostname, username and password.
# Verify OrionSDK SwisSnapin presence
if (!(Get-PSSnapin -Name "SwisSnapin" -ErrorAction SilentlyContinue))
    Add-PSSnapin SwisSnapin -ErrorAction SilentlyContinue
# Define Variables
$swis = Connect-Swis -Hostname my-orion-host.domain.com -Username alertbackup -Password My_Bogu$_P@55w01d
# Get all AlertIds, add to array
$AlertList = Get-SwisData $swis "SELECT AlertId FROM Orion.AlertConfigurations WHERE Enabled = True"
$AlertIds = $AlertList -split ' '
# Iterate through the Alertids array, back up each rule found
foreach($alertid in $AlertIds){
  $alerttitle = Get-SwisData $swis "SELECT Name FROM Orion.AlertConfigurations WHERE AlertId = $alertid"
  # remove all possible 'special characters' from the alert title
  $alerttitle = $alerttitle -replace '(#|\||"|,|/|Smiley Indifferent\<|\>|\[|\]|%|$|@|â|€|™|\?)', ''
  # remove all spaces from the alert title, replace with underscore
  $alerttitle = $alerttitle -replace '\s','_'
  $filename = "$alerttitle-ID-$alertid.xml"
  Set-Content $filename $ExportedAlert.InnerText
  $ExportedAlert = Invoke-SwisVerb $swis Orion.AlertConfigurations Export @($alertid)
# End script
I currently have this running as a scheduled task to backup all active alert rules daily, then commit changes to a git repository.
You may need to modify this PS script for your own environment.
This script has been tested on:
Windows 10 workstation
Windows Server 2012 R2
Windows Server 2016
Tags (2)
Comments
To make things more secure one trick you can do is to change line 26 like so
becomes
$swis = Connect-Swis -Hostname my-orion-host.domain.com -Trusted
Then you just set up your scheduled task to run under any Windows account that has permission to access Orion, that way you don't need to hard code or store credentials and can just rely on built in Windows security.  It's been a project of mine over the past year or two to always try to find ways to keep my scripts more secure.  Its deadly how many repos have hard coded creds and system names and such sitting in them that people forgot to clean up.
This is an excellent point! Thank you for sharing this tip and good advice. I'll update in a bit...
This worked gorgeously! Thanks for writing it. I don't suppose you have an import version of this? I've got 375 custom alerts to bring into a new deployment and would prefer not to do so one by one.
No I don't have an import script at this time. However I do understand the need to have one. I have around the same amount of alert rules (we have a very large NPM/SAM deployment).
There is an "import" function as documented in the OrionSDK wiki here: Alerts · solarwinds/OrionSDK Wiki · GitHub
I wouldn't expect it taking long to figure out how to do this. I'm thinking you just need to replace the logic in the foreach loop to look at each backup file on disk (i.e. each saved alert XML file) then use the import function.
The key is line 33 in the script. Instead of
`$ExportedAlert = Invoke-SwisVerb $swis Orion.AlertConfigurations Export @($alertid)`
you would use something like this...
`$ExportedAlert = Invoke-SwisVerb $swis Orion.AlertConfigurations Import @($alertid)`
I don't have time to test out an import script right now but this should be more than enough to get you started.
I've used this bit, for example, to sync up alerts between instances.  Pretty painless.
# get Alert IDs for enabled alerts
$AlertIDs = Get-SwisData -SwisConnection $swissource -Query "SELECT AlertID FROM Orion.AlertConfigurations WHERE Enabled = 'true' and name not like '%syslog%'"
# migrate the alerts
foreach ($AlertID in $AlertIDs) {
$AlertName = Get-SwisData -SwisConnection $swissource -Query "SELECT Name FROM Orion.AlertConfigurations WHERE AlertID = $AlertID"
$Existing = Get-SwisData -SwisConnection $swisdest "select name from orion.alertconfigurations where name = '$AlertName'"
    if ($existing.count -eq 0) {
                write-output "Migrating alert named: $AlertName"
                $ExportedAlert = Invoke-SwisVerb $swissource Orion.AlertConfigurations Export $AlertID
                Invoke-SwisVerb $swisdest Orion.AlertConfigurations Import $ExportedAlert
    else { "Alert named: $AlertName already exists, skipping" }
Version history
Revision #:
1 of 1
Last update:
‎01-15-2020 07:22 PM
Updated by:
Contributors
