UPDATE: Updated to 1.0.1 to fix exports of User Graphics Files
Because I'm constantly creating and destroying Orion instances in my currently capacity, I sometimes forget to export everything before I start working on the next instance. To that end, I started playing around with the Orion SDK and seeing if there was a way that I could rapidly export some content. The first thing time that I had this was when I stood up a new server and wanted to use my existing Network Path Troubleshooting map. I started to dig around a little bit and what to my wondering eyes should appear? No, not reindeer, but a 'table' called MapStudioFiles.
Then I broke out my PoSH hat and started tinkering. This is what I came up with:
File Name: Export-OrionMapFiles.ps1
Author: Kevin M. Sparenberg (https://thwack.solarwinds.com/people/KMSigma)
Purpose:
This script will export the Orion Maps (and associated files) from an active Orion System. By
default this script will export ALL maps and associated files (including images). To change it to
only export hte OrionMap files comment out or remove the "Exports only the Maps" region.
Export Path is to the current user's desktop. This can be modified within the "Setup Variables &
Connect to the SolarWinds Information Service (SWIS)" region.
IMPORTANT NOTE:
This version is set to use the "username/password" authentication process. This can be changed to
AD-credentials with some minor tweaking (TBD).
Prerequisites:
You must have OrionSDK Installed (Link: https://thwack.solarwinds.com/community/labs_tht/orion-sdk)
(tested with version 1.10)
Version History: [P = Past, C = Current, F = Future]
(P) 1.0.0 - Initial Release (2015-07-22)
(C) 1.0.1 - Update the path check for custom icons (2015-08-10)
(F) 1.1.0 - Conversion to a PowerShell Function (TBD)
(F) 1.2.0 - Allow for Multiple Authentication Types (TBD)
Tested against:
Orion Platform 2015.1.2
SAM 6.2.1
DPA 9.2.0
QoE 2.0
IPAM 4.3
NCM 7.4
NPM 11.5.2
NTA 4.1.1
OGS 1.0.10
WPM 2.2.0
SRM 6.1.11
Toolset 11.0.1
UDT 3.2.2
IVIM 2.1.0
VNQM 4.2.2
#region Setup Variables & Connect to the SolarWinds Information Service (SWIS)
Add-PSSnapin -Name SwisSnapin -ErrorAction SilentlyContinue
# The username for a user with admin level permissions
$SwisUsername = "admin"
# The poassword for said user (in plain text)
$SwisPassword = "@ppStack1"
# The IP, machine name, or alias for the associated Orion Instance
$SwisHost = "orionweb.demo.lab"
$SwisCredentails = New-Object -TypeName System.Management.Automation.PSCredential -ArgumentList $SwisUsername, ( ConvertTo-SecureString $SwisPassword -AsPlainText -Force )
# Export Path for the Files
$ExportPath = "$env:userprofile\Desktop\OrionMapFiles"
#endregion
#region Exports the Maps Only
$SwqlQuery = @"
SELECT FileName, FileData
FROM Orion.MapStudioFiles
WHERE FileType = 0 AND IsDeleted = False
ORDER BY FileName
#endregion
#region Exports the Maps and any associated files
$SwqlQuery = @"
WHERE IsDeleted = False
ORDER BY FileName
#endregion
#region Collect the files to a local object
$SwisConnection = Connect-Swis -Hostname $SwisHost -Credential $SwisCredentails
$OrionMapFiles = Get-SwisData -SwisConnection $SwisConnection -Query $SwqlQuery
$SwisConnection.Close()
$SwisConnection.Dispose()
Remove-Variable -Name SwisConnection -Force -Confirm:$false -ErrorAction SilentlyContinue
$TotalMapFiles = $OrionMapFiles.Count
#endregion
#region Check for Path Existence. If the path doesn't exist, then it's created.
if ( -not ( Test-Path -Path $ExportPath -ErrorAction SilentlyContinue ) )
Write-Host "Path: '$ExportPath' does not exist.`nCreating Export Folder..." -ForegroundColor Yellow
New-Item -ItemType Directory -Path $ExportPath | Out-Null
#endregion
#region Cycle through each file and export to the file system
For ( $i = 0; $i -lt $TotalMapFiles; $i++ )
Write-Progress -Activity "Exporting Orion Map Files" -CurrentOperation "Exporting $( $OrionMapFiles[$i].FileName )" -Status "Exporting $( $OrionMapFiles[$i].FileData.Length ) bytes" -PercentComplete ( ( $i / $TotalMapFiles ) * 100 )
#region Added for verison 1.0.1 for Custom Icons
# Check for the "Full Path" and create it, if it doesn't exist.
$ExportFullPath = ( Join-Path -Path $ExportPath -ChildPath $OrionMapFiles[$i].FileName )
$ExportDirectory = Split-Path -Path $ExportFullPath -Parent
if ( -not ( Test-Path -Path $ExportDirectory -ErrorAction SilentlyContinue ) )
Write-Warning "Creating [$( $ExportDirectory )] Folder"
New-Item -Path $ExportDirectory -ItemType Directory | Out-Null
#endregion
$OrionMapFiles[$i].FileData | Set-Content -Path ( Join-Path -Path $ExportPath -ChildPath $OrionMapFiles[$i].FileName ) -Encoding Byte -Force
Remove-Variable OrionMapFiles
Write-Progress -Activity "Exporting Orion Map Files" -Completed
#endregion
I'd love feedback from the community on what you think about this and what you think of my plans going forward.
