Hi All,
I am a c# developer and my application currently uses PowerShell based Swis integration which I want to replace by REST/JSON API as presented in SwisClient sample..
With PowerShell I can use the syntax "$swis = Connect-Swis -v2 -Trusted -host 10.10.10.1" to create a trusted connection using actual logon credentials.
How can I achieve the same functionality with the c# SwisClient ?
I guess I would need to modify below code, only don't know how :
private async Task<JToken> SwisCallAsync(Func<HttpClient, Task<HttpResponseMessage>> doRequest)
var handler = new WebRequestHandler
Credentials = new NetworkCredential(_username, _password),
PreAuthenticate = true,
ServerCertificateValidationCallback = ValidateServerCertificate
using (var client = new HttpClient(handler))
client.BaseAddress = new Uri(string.Format("https://{0}:17778/SolarWinds/InformationService/v3/Json/", _hostname));
HttpResponseMessage response = await doRequest(client);
var result = JToken.Load(new JsonTextReader(new StreamReader(await response.Content.ReadAsStreamAsync())));
if (!response.IsSuccessStatusCode)
throw new ApplicationException(string.Format("Server returned error: {0} {1}{2}{3}", (int)response.StatusCode,
response.ReasonPhrase, Environment.NewLine, result));
return result;
Thank you in advance.
