cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 10
Total bandwidth consumed by node over x period
Hello,
I am looking to use the data from SolarWinds to replace some of the competing monitoring systems we have. One requirement is showing total traffic over various predefined time periods (I have reduced the number of periods for this example).
I have the following query, and it works ok but it is super slow to run (taking ~10seconds to return 4 numbers) . Is there a better table, or can the query be refined to enable this?
SELECT Top 1
(SELECT SUM(InTotalBytes) as x FROM Orion.NPM.InterfaceTraffic WHERE NodeID = 5347 AND ObservationTimestamp >= '26/08/14 00:00:00') as InToday,
(SELECT SUM(OutTotalBytes) as x FROM Orion.NPM.InterfaceTraffic WHERE NodeID = 5347 AND ObservationTimestamp >= '26/08/14 00:00:00') as OutToday,
(SELECT SUM(InTotalBytes) as x FROM Orion.NPM.InterfaceTraffic WHERE NodeID = 5347 AND ObservationTimestamp >= '01/01/14 00:00:00') as InYear,
(SELECT SUM(OutTotalBytes) as x FROM Orion.NPM.InterfaceTraffic WHERE NodeID = 5347 AND ObservationTimestamp >= '01/01/14 00:00:00') as OutYear
FROM Orion.Nodes WHERE Nodes.NodeID = 5347
I would ideally like to have written it as follows, which I believe would have far greater performance, but I dont believe SWQL supports IF as a command.
SELECT
SUM(IF(ObservationTimestamp >= '26/08/14 00:00:00', InTotalBytes, 0)) as InToday,
SUM(IF(ObservationTimestamp >= '26/08/14 00:00:00', OutTotalBytes, 0)) as OutToday,
SUM(IF(ObservationTimestamp >= '01/01/14 00:00:00', InTotalBytes, 0)) as InYear,
SUM(IF(ObservationTimestamp >= '01/01/14 00:00:00', OutTotalBytes, 0)) as OutYear
WHERE NodeID = 5347
Any thoughts or pointers, gratefully received!
Oli
Tags (3)
0 Kudos
