SDK version 1.5
NPM version 10.2.2
I'm having trouble using SwisSnapin inside a PSremoting session. Using local SW credentials so there isn't any double-hop windows authentication issues, I can't seem to get it to connect successfully. My script works fine when run locally(even with the stored credentials), but as soon as it's done inside a WinRM session it stops connecting. I removed the secure string for purposes of posting, but the secure string method was generated by converting a working credential password to a secure string and then saving that string as a variable. This was tested working locally. You can do the same by using
$cred | Get-Credential
$password = $cred.Password | ConvertFrom-SecureString
and storing that value in the below string(although the value printed to the string is incomplete so I was able to use PowerGui to fetch the entire string value from the variable.
$ctxsess = New-PSSession -ComputerName "server.hostname.com"
Invoke-Command -Session $ctxsess -ScriptBlock {
Add-PSSnapin SwisSnapin
$username = "\release_team"
$secpassword = "securestring would be here"
$password = ConvertTo-SecureString -String $secpassword
$credential = New-Object System.Management.Automation.PsCredential($username,$password)
# Connect to Solarwinds server
$swis = Connect-Swis -v2 -host 'solarwinds.hostname.com' -Credential $credential
$nodes = Import-Clixml -Path E:\Scripts\Files\UnmanagedServers.xml
#UnManage Nodes
foreach($node in $nodes) {
$nodename = $node.DNShostname
$nodeid = Get-SwisData $swis "SELECT NodeID FROM Orion.Nodes WHERE DNS like '$nodename'"
Write-Output "Unmanaging $nodename : $nodeid"
$now=[DateTime]::Now
$later=$now.AddHours(6)
Invoke-SwisVerb $swis Orion.Nodes Unmanage @("N:$nodeid",$now,$later,"false")
Remove-PsSession -Session $ctxsess
