cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
SWIS Call returns empty array
Hello,
I try to retrieve data making https call (using a very simple SWQL query) to the SW Application Server, but I receive empty array, even though that the relevant query directly to the database client returns more records. Do you have any idea what is the issue? Could they be missing configurations? Thank you in advice.
FYI The relevant setup is quite new and until now I was working on an old one where I had not faced such an issue
Labels (3)
Tags (2)
0 Kudos
1 Reply
Any chance your user account has any kind of account restrictions or doesn't have the same level of permissions?
Assuming it's not that, a null array tells me you most likely have a valid syntax for the query in general but are you using any variables to filter it?  Maybe your variable is not resolving the way you had expected?
- Marc Netterfield, Github
0 Kudos
