Powershell script for Orion.AgentManagement.Agent
Hi Team,
I have to uninstall plugin from agents installed on multiple servers.
We can manually uninstall it from SWQL studio.
Can someone provide a powershell script to uninstall the agent plugin from multiple servers.
Prashant
  • Something like below should get you started. I haven't been able to test it yet, but it should at least get you pointed in the right direction.
    import-module SwisPowershell
    $swis = Connect-Swis -Host localhost -Certificate
    $agents = #Define Agents either via a query or a CSV of some sort
    $plugin = #define Plugin
    foreach($agent in $agents){
    Invoke-SwisVerb $swis Orion.AgentManagement.Agent UninstallPlugin @($agent, $plugin)
    sleep -m 200
    Write-Output "Script Complete. Exiting..."
