I'm trying to read and eventually update node interface custom properties via Python and the OrionSDK. From my understanding according to SolarWinds' very own URI documentation, the interface URI should be swis://abcdef/Orion/Orion.Nodes/NodeID=1/Interfaces/. However, when attempting to read this URI, I keep getting an HTTP error that appears to say that the URI doesn't exist. Here's the Python code I'm working with:
import requests
from orionsdk import SwisClient
def main():
requests.packages.urllib3.disable_warnings()
server = 'NPM_SERVER
username = 'ADMIN_USER'
password = 'ADMIN_PASS'
swis = SwisClient(server, username, password)
print("Custom Property Update Test:")
results = swis.query(
"SELECT Uri FROM Orion.Nodes WHERE NodeID=@id",
id=3007
uri = results['results'][0]['Uri']
obj = swis.read(uri + "/Interfaces")
print(obj)
if __name__ =="__main__":
main()
And here's the error I'm getting:
requests.exceptions.HTTPError: 400 Client Error: Invalid key properties specified for entity Orion.NPM.Interfaces.
Parameter name: filter for url: NPM_SERVER:17778/.../Interfaces
As mentioned previously, all I'm trying to do at this point is print out the interfaces on the node and, eventually, set those interface custom properties. Any help and guidance to start this process would be great. Thank you!
