I need to configure account limitations and assign menu bars/views using API.
How to create account limitation using API?
You'll just need to invoke the verb as described in this documentation from the sdk wiki:
SolarWinds Information Service v3.0 Schema Documentation
As far as finding out exactly how to format what you want, usually the easiest way is to create one in the GUI, then see how it shows up on the back end and write your code to reproduce that
