When doing an update post to attempt to enable/disable specific components of an application monitor that's been applied to a node, it actually pushed the update to EVERY component in the system (so disabled every component on every application monitor in the entire system). Can someone assist with the proper way of doing this?
I've tried 2 different methods: Using the SWIS URI in the POST URL with the payload simply being the JSON string to set "Disabled": true, and also the BulkUpdate URL with the single URI and parameter defined in the payload. Both methods did the systemwide toggle.
Thoughts? Thanks!
