I'm using the REST API to create nodes and assign pollers - it works great.
But I'd also like to be able to assign a Device Studio poller to a node after I've created it (mostly so that the node is assigned the correct MachineType - the MIBs I am working with are not publicly available).
Unfortunately SQLStudio shows that the Orion.DeviceStudio.PollerAssignments object is not write-able:
There also seems to be no verb which will enable this.
Is there any method I can use to assign a node to a device studio poller via the REST API, or if not do you know of any plans to add support for this in a future release?
