cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 9
Add a node to a container using Python
Jump to solution
Hello Community,
      Does anyone know how to add a node to a container without using a dynamic query in Python? I got the dynamic query to work, but wanted to see if there is a way to add the nodes to the groups directly without a dynamic query.
Thank you,
JAF
0 Kudos
1 Solution
Level 19
Adding a single object to a group is almost the same as adding a filter rule to a group. In place of the filter, put the Uri of the object you want to add. For example, to add node 33 to group 8, do this:
swis.invoke('Orion.Container', 'AddDefinition', 8, {'Name':'cpe','Definition':'swis://tim.swdev.local/Orion/Orion.Nodes/NodeID=33'})
Level 19
Thank you TDanner! I had added one manually and checked the database to see what the definition looked like and then saw your answer to confirm it. I appreciate your help!
Thank you,
JAF
0 Kudos
