cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
NTM Not Returning System Information
NTP is creating maps of my subnets, however, it is only returning IP addresses.
I have the node display options selected and have entered the correct credentials.
I ran a test scan to map only devices that returned more that just ICMP.  The only device it returned
was the server that NTM is hosted on. Polling method was WMI and it returned the information I was seeking
I'm new to NTP and would appreciate any help.
Thank you!
0 Kudos
1 Reply
Level 15
If you are using SNMP, you can test with an SNPM walk.  You will want to go to Help\Support Tools\Grab SNMPWALK
0 Kudos
