cancel
Showing results for
Search instead for
Did you mean:
Create Post
Cisco Catalyst 4500 Supervisor Engine 7-E
flow record record1
     match ipv4 source address
     match ipv4 destination address
     match interface input
     match transport source-port
     match transport destination-port
     match ipv4 protocol
     match ipv4 tos
     match ipv4 dscp
     collect routing forwarding-status
     collect routing source as
     collect routing destination as
     collect transport tcp flags
     collect interface output
     collect counter packets long
     collect counter bytes long
     collect timestamp sys-uptime first
     collect timestamp sys-uptime last
flow exporter exporter1
     destination 192.168.154.2
     source VLAN1
     transport udp 9999
     template data timeout 60
flow monitor monitor1
     record record1
     exporter exporter1
     cache timeout inactive 30
     cache timeout active 60
     cache entries 1000
interface GigabitEthernet 0/1
     ip flow monitor monitor1 layer2-switched input
Version history
Revision #:
1 of 1
Last update:
‎10-04-2013 03:05 AM
Updated by:
