When I install a new polling engine should i see a GUI for this ? Or, is this just a polling engine i will see from my main instance?
Solved! Go to Solution.
The only web portal comes from the primary poller (the first polling engine you install). There's no additional GUI or website.
From now on, when you add nodes, you'll see an option to add it to the primary (first) or additional (second) polling engine.
Awesome! Thanks for the quick response...
SolarWinds solutions are rooted in our deep connection to our user base in the THWACK® online community. More than 150,000 members are here to solve problems, share technology and best practices, and directly contribute to our product development process.
