Hello Everyone
We are deploying NTA and am getting everything fined tuned. So far everything is working great but have been starting to get these errors "is receiving flow data from unmanaged interface '#xxxx and does not support SNMP" . I am getting these errors from our ASAs and our Cisco 3850s. I read online that the fix for most Cisco devices is snmp-server ifindex persist which i have deployed to our 3850s. I also read that the 3850s have this set by default and am still getting these errors. The ASAs are also reporting this error and does not look like they support the above command,
Any help be greatly appreciated
Hey jasonflory
Are all of the problem devices managed via SolarWinds? Are you receiving other monitoring information from them, and the other interfaces, correctly?
Yes the devices work for regular snmp information and Netflow. I just get constant alerts stating I am getting Netflow info from unknown interface which is not supported by snmp.
What I would check is the device configuration. it could be that every device had NetFlow enabled using a script, and there was a mistake with it which is causing NTA to throw up errors. Any chance you could post a snippet of the config showing just the NetFlow commands? (sanitised to remove sensitive information, natch).
Hmm i think the change i pushed out via NCM actually fixed this. Took a bit but i am now not getting this error. This was recommendation from another post to change the snmp interface number to persistent.
snmp-server ifindex persist was run on all of our Cisco switches.
Lets see if any of these errors come back. Just to share here is the config we have on our 3850s for netflow. the standard config templates for netflow would not work on the 3850s.
flow record NETFLOW-RECORD-IN
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
collect transport tcp flags
collect interface output
collect counter bytes long
collect counter packets long
collect timestamp absolute first
collect timestamp absolute last
collect counter bytes layer2 long
flow record NETFLOW-RECORD-OUT
match ipv4 tos
match ipv4 protocol
match interface output
collect interface input
flow exporter NTAexport
destination xxxxx
source Vlan2
transport udp 2055
template data timeout 60
flow monitor NETFLOW-MON-IN
exporter NTAexport
cache timeout active 60
flow monitor NETFLOW-MON-OUT
exporter NTAexport
Both monitors are assigned to each interface.
SNMP config
snmp-server community xxxxx
snmp-server community xxxxxx
snmp-server location xxx
snmp-server contact xxx
snmp-server chassis-id xxxxxx
snmp-server host xxxx
snmp ifmib ifindex persist
Good stuff! Hope that's sorted out your issue, jasonflory!
The only devices that i could not run that SNMP command on was the ASA which are also reporting these virtual interfaces as well but they seem to have stopped too.
SolarWinds solutions are rooted in our deep connection to our user base in the THWACK® online community. More than 150,000 members are here to solve problems, share technology and best practices, and directly contribute to our product development process.
