cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 10
NetFlow from Huawei & HP Switches
Dear Team,
We have set the NetFlow Configuration of the Devices. However, the interfaces on which NetFlow is configured is not added to NPM. We have enabled NetFlow from Unknown Source. In the NetFlow windows, these devices are still showing no Flows. Which we checked using Wireshark, Flows are coming. The Configuration put on Device is as below:
[12:32, 31/03/2020] Bader Tariq: this is for Huawei
[12:32, 31/03/2020] Bader Tariq: SYSTEM-VIEW MODE
Sflow agent x.x.x.x (management IP of switch)
Sflow collector 2 ip 10.222.16.169* port 2055
*depending on what is the polling engine for the switch. Can be 10.222.16.169 10.222.16.170 or 10.222.16.171
INTERFACE MODE(CONNECTED TO MPLS ROUTER)
sflow counter-sampling collector 2
sflow counter-sampling interval 120
sflow flow-sampling collector 2
sflow flow-sampling rate 4000
Kindly assist us.
0 Kudos
1 Reply
Level 16
You stated the following below have you added these interfaces into Orion?
0 Kudos
