NetFlow Setup Problem
I'm pretty new to this & am trying out the NteFlow monitor in Orions (v8).
I have installed the NetFlow component to an existing Orion-v8 setup & the install process looked fine.
For some reason I am getting a yellow message in the NF Traffic Analyzer telling me:
NetFlow Receiver Service [NMA-ORION] is receiving a NetFlow data stream from an unmanaged interface on 172.16.0.226. The NetFlow data stream will be discarded. Please use the Orion System Manager to add Interface #11 in order to process this NetFlow data stream.
That IP address is a 2621 router that has all interfaces (S & FA) monitored in the NPM setup. NPM seems to work just fine looking at the data from the router. I am interested in the WAN data from the S0 interface, so I have setup the "ip route-cache flow" and "ip flow-export..." stuff for S0.
However, the message... & I don't know what it means by "Interface #11" anyway....
Can anyone help??
Simon
  • I'm told they will be adding a feature to the upcoming release that will let you pick specifically which interfaces you want to accept data from on the netflow engine. Until then, I think the #11 refers to the IFindex value. You can pull this with an snmpwalker.
    Paul
  • You can also run the following and get the if index number...example below...
    sumcompanyswitch#sho snmp mib ifmib ifindex
    EOBC0/0: Ifindex = 124
    GigabitEthernet1/1: Ifindex = 1
    GigabitEthernet1/10: Ifindex = 10
    GigabitEthernet1/11: Ifindex = 11
    GigabitEthernet1/12: Ifindex = 12
    GigabitEthernet1/13: Ifindex = 13
    GigabitEthernet1/14: Ifindex = 14
    GigabitEthernet1/15: Ifindex = 15
    GigabitEthernet1/16: Ifindex = 16
    GigabitEthernet1/17: Ifindex = 17
    GigabitEthernet1/18: Ifindex = 18
    GigabitEthernet1/19: Ifindex = 19
    GigabitEthernet1/2: Ifindex = 2
    GigabitEthernet1/20: Ifindex = 20
    GigabitEthernet1/21: Ifindex = 21
  • FormerMember
    0 FormerMember
    You can also use the EE toolset "MIB Browser" to find the if index.
    Use MIB "IF-MIB:ifXTABLE" (1.3.6.1.2.1.31.1.1) to view the info for your router/switch. It will give you the index correlation to the slot/port.
  • If you right click on an interface in the Orion System Manager and select Interface Details you will also be able to see the if index
  • FormerMember
    0 FormerMember in reply to FormerMember
    This selection feature is available in NTA 2.0.
    Denny LeCompte
    Sr. Product Manager, Orion
    SolarWinds
