Okay I give up trying to find out the correct way of creating NTA report that will tells me about how much percent utilization of my interface bandwidth.
The only reports I can manage to create is to tell how much bytes of an application that is passing through an interface within a specified time range but I don't get the idea how much it utilizes my bandwidth.
What I want is to create a report that will tells me an average percent of my interface utilization within a specified time range, and then breaks down the utilization itself into list of applications and its corresponding percent utilization. For example: let's say I got average 75% bandwidth utilization within the last 24 hours, then using this report I can know that the 75% consists of 30% application A, 15% application B, 20% application C, and 5% others (application A, B, and C has been predefined in monitoring settings).
It's a very simple requirement and I know software as complex as Solarwinds NTA should have this capability, it's just I can't find the way to create a report for this. Tried using Orion object netflow by history, netflow by interface history, etc... but all I can get is the amount of bytes through! Not even I can get it to show the transmit/receive rate of an application.
Please kindly advise.
