select 'Status' as [c] , concat('<img src="/Orion/images/StatusIcons/Small-',StatusLED,'"></>' ,'<a href="/Orion/View.aspx?View=NodeDetails&NetObject=N:',cast(v.volumeid as varchar),'"> ' ,si.StatusName,'</>') AS [v] from volumes v join statusinfo si on si.StatusId=v.Status where volumeid=${volumeid} union all ( select 'Type' as [c] , concat('<img src="/NetPerfMon/images/Volumes/',volumetypeicon,'"></> ' , v.VolumeType) as [v] from volumes v where volumeid=${volumeid} ) union all ( select 'Space Usage' as [c] , concat( case when v.VolumePercentUsed > isnull(fc.criticalthreshold,gcrit.crit) then '<img src="/Orion/images/StatusIcons/Small-critical.gif"></> ' when v.VolumePercentUsed > isnull(fc.criticalthreshold,gwarn.warn) then '<img src="/Orion/images/StatusIcons/Small-warning.gif"></> ' else '<img src="/Orion/images/StatusIcons/Small-up.gif"></> ' end , round(case when v.VolumeSize > 1099511627776 then (v.volumespaceused/1099511627776) when v.VolumeSize > 1073741824 then (v.volumespaceused/1073741824) when v.VolumeSize > 1048576 then (v.volumespaceused/1048576) when v.VolumeSize > 1024 then (v.volumespaceused/1024) else v.volumespaceused end,2) , case when v.VolumeSize > 1099511627776 then ' TB ' when v.VolumeSize > 1073741824 then ' GB ' when v.VolumeSize > 1048576 then ' MB ' when v.VolumeSize > 1024 then ' KB ' else ' Bytes ' end , ' used (',round(v.VolumePercentUsed,0),'%) of ' , round(case when v.VolumeSize > 1099511627776 then (v.VolumeSize/1099511627776) when v.VolumeSize > 1073741824 then (v.VolumeSize/1073741824) when v.VolumeSize > 1048576 then (v.VolumeSize/1048576) when v.VolumeSize > 1024 then (v.VolumeSize/1024) else v.volumespaceused end,2) , case when v.VolumeSize > 1099511627776 then ' TB ' when v.VolumeSize > 1073741824 then ' GB ' when v.VolumeSize > 1048576 then ' MB ' when v.VolumeSize > 1024 then ' KB ' else ' Bytes ' end ,' total size') as [v] from volumes v cross join (Select CurrentValue AS crit FROM Settings WHERE SettingID = 'NetPerfMon-DiskSpace-Error') gcrit cross join (Select CurrentValue AS warn FROM Settings WHERE SettingID = 'NetPerfMon-DiskSpace-Warning') gwarn left join ForecastCapacitySettings fc on fc.InstanceId=v.VolumeID and fc.MetricId = 3 where volumeid=${volumeid} ) union all ( select 'Warning Threshold' as [c] , case when fc.warningthreshold is not null then (concat(fc.warningthreshold,'% (Custom)')) else (concat(gwarn.warn,'% (Default)')) end as [v] from volumes v cross join (Select CurrentValue AS warn FROM Settings WHERE SettingID = 'NetPerfMon-DiskSpace-Warning') gwarn left join ForecastCapacitySettings fc on fc.InstanceId=v.VolumeID and fc.MetricId = 3 where volumeid=${volumeid} ) union all ( select 'Critical Threshold' as [c] , case when fc.criticalthreshold is not null then (concat(fc.criticalthreshold,'% (Custom)')) else (concat(gcrit.crit,'% (Default)')) end as [v] from volumes v cross join (Select CurrentValue AS crit FROM Settings WHERE SettingID = 'NetPerfMon-DiskSpace-Error') gcrit left join ForecastCapacitySettings fc on fc.InstanceId=v.VolumeID and fc.MetricId = 3 where volumeid=${volumeid} ) union all ( select 'Last Polled' as [c] , cast(max(vp.DateTime) as nvarchar) as [v] from volumes v join VolumePerformance vp on vp.VolumeID=v.VolumeID where v.volumeid=${volumeid} group by v.volumeid ) union all ( select 'Polling Interval' as [c] , concat(cast(v.PollInterval as nvarchar),' seconds') as [v] from volumes v where v.volumeid=${volumeid} ) union all ( select 'Statistics Interval' as [c] , concat(cast(v.StatCollection as nvarchar),' minutes') as [v] from volumes v where v.volumeid=${volumeid} ) union all ( select 'Rediscovery Interval' as [c] , concat(cast(v.RediscoveryInterval as nvarchar),' minutes') as [v] from volumes v where v.volumeid=${volumeid} )
