cancel
Showing results for
Search instead for
Did you mean:
Create Post
NPM 2020.2 RC Feature Deep-Dive: MIBs Database Management
NPM 2020.2 RC now available!
It's my pleasure to introduce our latest release candidate of Network Performance Monitor, available now in your customer portal.
Version 2020.2 is the next release following NPM 2019.4 and is compatible with the Orion Platform 2020.2. This is the second of three articles diving into the new features of this release, with this one focusing on MIBs Database Management. The other major features delivered in this release are Microsoft Azure Networking and Device View Improvements. More information on this release can be found in the RC Announcement
As I'm sure many of you already know, vendor SNMP implementations rely on semi-proprietary Management Information Bases (MIBs). The MIBs Database in NPM is a massive conglomeration of all the MIBs from all the vendors, and it powers features like UnDP. Prior to this release of NPM 2020.2, the process to update your local NPM deployment's MIBs Database with our latest and greatest version has been rather cumbersome.
While it's still not quite as streamlined as we'd like, NPM 2020.2 brings massively improved integration of the MIB Database into the Orion Web Console. You can check your current version of the MIBs Database, find out whether a newer version is available, and download the latest version - all directly from the Orion Web Console.
You can access the new MIBs Management page under Settings > All Settings > Details.
From this page, you can easily check the status of your MIBs Database and download the latest version directly from the Orion Web Console. Unfortunately, we didn't have time to finish integrating the installation process into the console yet, and so this process will presently need to be completed by accessing the Orion Web Console directly from your Orion server. Additionally, the process will need to be repeated manually on Additional Polling Engines (APEs) to ensure a consistent user experience with UnDP in your environment. We hope to further improve this workflow to be even more automated in a future release.
For more detailed information, check out the NPM 2020.2 RC Administrator's Guide!
With this NPM RC, comes some fantastic new updates & enhancements to the Orion Platform which include:
  • Monitor up to 1,000,000 elements per Orion Platform instance.
  • An Orion Map to Success! - Orion Maps improvements, such as creating and customizing text boxes, labels, or layouts, incorporating custom icons, adding shapes, dynamic backgrounds, bulk administration and all-new Time Travel.
  • Performance enhancements.
  • Dashboards, Dashboards, Get Your Dashboards! All New Custom Summary Dashboards
  • A Gateway To Your Fastest Upgrade Ever! - Upgrade improvements, such as pre-staging upgrades, upgrade plan reports, automating upgrades via Orion SDK.
  • Enhanced volume status.
  • 3rd Party Language Pack Support - scripts to extract UI texts from the Orion Web Console.
Your Feedback Counts!
The NPM team is incredibly interested in your feedback, and on top of that, when you participate by downloading and installing the RC, you get THWACK points. More importantly, your feedback shapes how we develop our products. Post your thoughts, questions, and concerns into the RC forum and not only will you be able to get some SolarWinds swag, but you may help to make NPM a better product. If you have a particularly compelling idea, you should also consider putting in a Feature Request and encouraging others to vote on your idea.
Comments
@jason.carrierHow do the new MIB processes for checking whether the local MIB needs updating and for updating the local MIB file affect Orion installations not connected to the Internet? Will there still be a place at solarwinds.com to check the most up-to-date MIB and compare it wpith the local one manually? Where will any new MIB be prepositioned locally to allow the new web-based update to see it? Are any shut downs/restarts of processes required, even if handled behind the scenes?
Hi @mjperkins
Thanks for your questions.
  • If there is not internet connection = there is not any check (automatic) so it doesn’t work
  • Yes 🙂 Manually it has same procedure like before = no changes = same places
  • Unfortunately, currently not = there is not any locally place where Orion is looking / check new version of MIBs = Orion is looking directly to Solarwinds portal
  • like is mentioned in post, installation is still manually = part of MSI installation of new MIB database is automatic restart of specific services. So it is not necessary to do any other restart, just install MSI
Daniel
Daniel's response is spot on. Let me know if there are any other questions!
@jason.carrier,
Would it be possible to get the version number and/or publish date for the MIB database shown on the download page?  Looking at the MIBs.cfg, I don't see a way to determine if the one downloaded is newer than the one installed (beside the upcoming 2020.2 method).
@Martin_Crothers
We just updated to 2020.2RC and got this when browsing the Mib manager on our instance. 1.1.0.180 is the version 2019.4 had as default installed DB.
MIBs database is out-of-date
1.1.0.180 Installed
1.1.0.188 Available
2 awesome things-- MIB downloader in console and the number of elements per Instance...
Version history
Revision #:
3 of 4
Last update:
‎05-01-2020 03:48 PM
Updated by:
