cancel
Showing results for
Search instead for
Did you mean:
Liebert UPS
Liebert UPS
Pollers for the following:
BatteryTimeRemaining
Battery Capacity
PowerLineMeasurementCurrent
PowerLineMeasurementVolts_Input
PowerLineMeasurementVolts_Output
PowerLinePointVAPercent
TempMeasurementDegC
Most are setup in charts so they can be trended.
Cheers
Labels (1)
Comments
None of these worked on our Liebert NPower 130KVA.
We are using these on Liebert UPS that use the Intellislot Web Card. We have not tested this on anything else.
Hi guys,
we would like to add native support of Liebert UPS devices. Could you please send us SNMP walks for investigation purposes?
thanks,
Michal
Thank you! I am currently using this on a Liebert eXM.
I am not getting data from the following pollers:
lgpPwrLineMeasurementVolts_input   No Data
lgpPwrLineMeasurementVolts_output   No Data
lgpPwrMeasurementPointVAPercent   No Data
Some of the data is not formatted correctly. I'm going to attempt to troubleshoot the BatteryCapacity and Temperature
BatteryTimeRemaining    67 m   9:05 AM
lgpPwrBatteryCapacity    2   9:05 AM
lgpPwrLineMeasurementCurrent    28   9:05 AM
PercentageTransform    Unable to complete transform. See KB article 4779 for possible reasons.   9:05 AM
TemperatureMeasurementDegC    2 value(s)c
If anyone is monitoring eXM with Solarwinds, please chime in on what is working for you.
Regards--
Version history
Revision #:
1 of 1
Last update:
‎06-08-2009 12:00 AM
Updated by:
Contributors
