Report that counts how many interfaces, Volumes, and Components that a node is using in Orion.
*Note: Requires both NPM and SAM to be installed.
If you open the XML up or import it then you will find the SWQL inside:
SELECT n.Caption ,n.NodeID AS [Node] ,n.Interfaces.InterfaceID AS [Interfaces] ,n.Volumes.VolumeID AS [Volumes] ,n.Applications.Components.ComponentID AS [Components] FROM Orion.Nodes n
