cancel
Showing results for
Search instead for
Did you mean:
Create Post
Interface Discovery by Description or Identify Uplinks
This script manipulates the Orion Discovery tables to set interfaces matching your description, or interfaces with more than 2 mac addresses connected as "up" for import.
READ THE ATTACHED DOC FOR EXAMPLE USAGE
Works in v10.0.
THIS SCRIPT IS NOT SUPPORTED BY SOLARWINDS.
Labels (1)
Tags (1)
Comments
This is awesome. I looked at running ODBC in Perl, and it scared me off. This looks great.
Version history
Revision #:
1 of 1
Last update:
‎08-26-2010 12:00 AM
Updated by:
