This resource shows durations of any nodes or interfaces.
Any question here http://thwack.solarwinds.com/thread/17899
Thank you. The code works on NPM 10.4.2
But you need replace "Gb's_DetachResource" with "Gbs_DetachResource" in file:
HowLongEachNodeWasDownSummary.ascx.cs
HowLongEachInterfaceWasDownSummary.ascx.cs
Gb's_DetachResource.aspx.cs
and rename
Gb's_DetachResource.aspx to Gbs_DetachResource.aspx
Gb's_DetachResource.aspx.cs to Gbs_DetachResource.aspx.cs
IIS does not like ' in the file name
Thanks Again
