This is a custom SQL alert that triggers when the volume usage (percent utilization) of a hard disk (fixed disk) increases by more than 20% over 24 hours. The percentage value and hour time-frame can be modified in the custom SQL trigger conditions.
When triggered, the system will write to the Orion Event Log.
