HP C7000 Blade Slot Info
The UNDP Attached to this post works on showing the Blade Slot info Including the Blade Name and Serial, Slot Number, and Slots Used  Some math and logic would  be needed to ingest the last slots used numbers.  The C7000 has the capability of many slot configurations so you need to know once using a tabular device poller or poller status which amount of slots your chassis is configured for.  Then you can play with the labels to find out the slot or and configuration once in the widget label selection.  Let me know if you need help with this.  I can send screen shots or help with configuration.
