cancel
Showing results for
Search instead for
Did you mean:
Emerson Network Power Liebert UPS Device Poller
Emerson Network Power (Closet Class UPS for Edge Switches)
Manufacturer Liebert Corporation
Liebert UPStation GXT
 http://www.liebert.com/common/ViewDocument.aspx?id=286
Configure an advanced alert trigger condition to notify you when upsSecondsOnBattery is NOT equal to 0. This is when the UPS switched to Battery Back Up.
In that same alert configure the reset condition to notify you when upsSecondsOnBattery IS equal to 0. This is when inline power has returned.
 To display the custom poller you will have to add it to your node details page in NPM.
Cheers,
Koz
Labels (1)
Comments
Tested and working on GXT2-1500RT120
Specs
How do you get upsSecondsOnBattery to show up in your alert criteria since its a dropdown?
Glad you got it figured out Robust 57. Recent NPM upgrades also allow you to display it as a gauge, attachments to follow.
Hmmm, I configured the alert but it doesn't work for me. Could we revisit this discussino?
Hi Butch,
Sent you an email.
Koz
All good
Wondering how you have the bar gauge. I only have radial options.
Disregard
How did you get the bar guage I cant find it anywhere?
Hi zmclean@ncra.coop,
On the node details page select "Customize this page" add the custom poller to it and you can select the gauge from any of the ones available.
Koz
nvm.. i figured it out. thanks
Hi Koz,
I am new to this, I just downloaded the UPS poller, what now?
Hi guys,
we would like to add native support of Liebert UPS devices. Could you please send me (michal.hrncirik at solarwinds.com) SNMP walks for investigation purposes?
thanks,
Michal
Does this work for IntelliSlot IS-UNITY-DP devices?
I've imported one UnDP file for Liebert and most of the Pollers didn't work correctly.
Thanks all!
Update: This did not work for my IS-UNITY Card. I had to create my own pollers by trial and error in the Universal Device Poller application. I'll post my UnPD profile once I finish tuning it.
Regards--
Version history
Revision #:
1 of 1
Last update:
‎06-02-2010 12:00 AM
Updated by:
koz
Contributors
