cancel
Showing results for
Search instead for
Did you mean:
Create Post
Custom Pollers for CPU and Memory Utilization of Fortigate devices
The file includes 2 Pollers
CPU Usage - SNMP GET on 1.3.6.1.4.1.12356.101.4.1.3.0
Memory Usage - SNMP GET on 1.3.6.1.4.1.12356.101.4.1.4.0
It is set to retain historical data.
Once you import the custom pollers from the Universal Device Poller utility, be sure to
- right click on the pollers and Assign them to the relevant nodes
- right click on the pollers and choose the Web Display options (Gauge and Chart options for 'Node Details - Summary' view is recommended)
Labels (1)
Comments
Thanks for posting- interesting timing...
Also check out the 10.7 RC released today: NPM 10.7 RC1 Now Available
We have a built in custom poller for Fortimanager. If for some reason it doesn't work, you would simply need to map the OIDs above to the CPU / Memory fields.
For those that are looking for an updated device poller for a Fortigate (CPU & Memory) under Device Studio in NPM 10.7 / 11.x or higher, you may want to consider downloading this:
Fortigate CPU & Memory Poller
Hope it helps out if you have these in your environment and are wanting the CPU & Memory info.
Cheers!
-Marek
P.S. And a thanks to HolyGuacamole for the initial posting of the UnDP (saved me time looking up the OIDs and more).
Version history
Revision #:
1 of 1
Last update:
‎01-22-2014 09:37 PM
Updated by:
