cancel
Showing results for
Search instead for
Did you mean:
Current Hardware Temperature
Comments
I tried this one... pretty cool.  From looking at the number it must by default show temp (Hardware Sensor Value)  in Celsius I'm guessing because the numbers are low.
That is correct. All values are stored in the database in the vendor's native unit of measurement, being Celsius.
I am getting an error while importing the report:
This is a report written in the Legacy Win32 Report Writer application. As such, you will need to download the file and place it in the 'C:\Program Files (x86)\SolarWinds\Orion\Reports' directory on your main Orion server.
Hi, Thank you! great I can see the details. but I wanted to know like do we have any option through which we can extract the temperature details (in numeric value not in the graph) for a single switch of last 3 months?
Version history
Revision #:
1 of 1
Last update:
‎10-03-2013 03:42 PM
Updated by:
