cancel
Showing results for
Search instead for
Did you mean:
Create Post
Airedale - Carel PCOWeb Interface
Returning the Favour..
Attached is a Collection of UDP's for monitoring an Airedale CRAC fitted with a PCOWeb Interface, manufactured by Carel. Took a bit of piecing together this one and will depend on which sensor is wired into which Digital and Analogue ports, you might want to check it's reporting corectly for your CRAC.
For completeness this is used on a V31X2
Labels (1)
Version history
Revision #:
1 of 1
Last update:
‎08-13-2010 12:00 AM
Updated by:
