cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
windwos7 home edition and IIS
please i want to know if i can install NPM 10 in wind7 home edition, becuse i afce problem with IIS.
thanks
0 Kudos
Level 10
As far as I know, you cannot install IIS7 to W7 Home Edition, you need at least W7 Premium, so the answer is not, you cannot install NPM10 to W7Home Edition.
0 Kudos
Level 14
fu2000,
While evaluation installations are permitted, SolarWinds does not support production installations on Windows 7.
IIS is required for the Orion Web Console. If you have a problem with IIS, I would suggest providing more details here, so the community can assist, consulting the Orion NPM and Orion Common Components Administrator Guides or submitting a technical support ticket with SolarWinds Support.
HTH,
0 Kudos
