cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 8
using SWQL to create a custom filter to exclude a specific drive
Good day all,
I am working on creating a custom filter for a list of volumes to list only those of a specific group of servers whose volume utilization is greater than 80% but exclude one specific HD.  I have everything working except for the exclusion.  Here is the basic information:
SWQL Statement:   VolumeType LIKE 'Fixed%' AND VolumePercentUsed > 80
The drive I am trying to exclude is below:
 Node ID 1194
 VOLUME P:\ Label:PAGEFILE Serial Number B45A9136
 TYPE
Fixed Disk
 SIZE 100.0 GB
 SPACE USED 96.8 GB
 SPACE AVAILABLE 3.2 GB
 PERCENT USED 97 %
 PERCENT AVAILABLE 3 %
Could use a little help.  Thanks all!
0 Kudos
1 Reply
Level 12
Have you tried adding AND DisplayName NOT LIKE '*<Filter_Criteria>*' at the end of your SWQL query?
0 Kudos
