cancel
Showing results for
Search instead for
Did you mean:
Create Post
need some help with report filters
Jump to solution
Hi All
I'm looking to edit the Historical - Response Time and Packet Loss report to give me a snapshot of the peak and average response times for the routers at our remote depots
so I want the entries for midnight (00.00) for a selection of our nodes
I think I want to do something like:
select records where all of the following apply
Select records where Hour of Day is equal to 0 (just this part of the query on its own works fine)
select records where any of the following apply
records where Node ID is equal to 147
Records where Node ID is equal to 148
up to line 5 returns node 147 at 00.00
adding line 6 returns nothing
line 6 is not indented in the way that line 5 is
so I'm a bit stuck now and looking for some help
thank you in advance
Laurence
Labels (2)
0 Kudos
1 Solution
As long as you keep adding by selecting the last condition on the list and picking "Add a new elementary condition", you should be able to create a long list.
You can also create ranges for the sequential NodeID's. I'm going to try to attach a screenshot. I am on NPM 11.5, not sure if that matters or not.
0 Kudos
Level 9
I configured the same report. Mine looks like this and works:
Select records where all of the following apply
  Records where Time of Day (24 hour format) is greater than or equal to 00:00:00
  Records where Time of Day (24 hour format) is less than or equal to 00:02:00
  Select records where any of the following apply
    Records where NodeID is equal to 147
    Records where NodeID is equal to 148
The way it is indented is important.
I hope that helps.
0 Kudos
Hi cjarocki
thank you for your reply. I have worked through your suggestion
I want to report on nodes:
147, 148, 149, 150, 151, 152, 153, 155, 156, 157, 158, 159, 160, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 253, 255, 257, 265, 268, 291, 361, 362, 364, 365, 367, 386, 390, 393
but I seem only to able to add three elementary conditions at the required nest level so I'm stuck again
regards
Laurence
0 Kudos
0 Kudos
thats sorted it
thank you
0 Kudos
