cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
need help with complex alerting
Jump to solution
I am building a alert based on a UnDP to get power supply information from Cisco Nexus switches and their attached FEXs.  The alert should fire any time the "on" condition is not met for the 6 RowIDs I have listed.
I am getting the following errors when I try to save the alert.
I could use all the help I can get.
Labels (1)
Tags (4)
0 Kudos
1 Solution
Level 7
I figured it out.  The last condition should have been under the main trigger all container.
0 Kudos
Level 7
0 Kudos
Level 9
Hi -
Can you please let me know how are you monitroing the power supply of Nexus family ?
0 Kudos
