cancel
Showing results for
Search instead for
Did you mean:
Create Post
Highlighted
Level 8
Web Sound Alert
HI,
Is there any manual reference on how to configure the web sound alerts in 8.1? Is it possible to use the Advanced alert config to trigger the web browser sound alert? How do you add new sounds?
0 Kudos
Highlighted
Level 17
Re: Web Sound Alert
You can add sounds to this folder C:\Inetpub\SolarWinds\NetPerfMon\Sounds and when you configure an alert which triggers a sound the list of sounds to choose from will be in the drop down box-
0 Kudos
Highlighted
Level 19
Re: Web Sound Alert
It's in the Admin Guide here:
http://www.solarwinds.net/NetPerfMon/SolarWinds/wwhelp/wwhimpl/common/html/wwhelp.htm?context=SolarWinds&file=OrionAdministratorGuide.1.157.htm
0 Kudos
