cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 8
Vlan Utilization using Orion V9
unable to obtain utilization on any of Vlans i have in my network. Using Cisco 6500 series switches with MFSC2 for layer 3. i've tried changing the speeds from the default to numerous other speeds with no results. i guess the bottom line question is does Orion even support the monitoring of utilization for Vlans? I've had a ticket open for almost 3 months and i'm getting no response back from them.
Tags (1)
0 Kudos
Level 7
It is a bug with V9. Checkout this thread.">
0 Kudos
thanks. when i was running 8.5.1 i was havingthe issue and was told it was going to be fixed in V9....oh well.
0 Kudos
