I have upgraded to 8.5 and applied the hotfix. However, strange things still going on. I already tried the "Rename \Inetpub\Solarwinds\Orion\custom.config.txt to custom.config" trick - that didn't solve anything. In fact, when leaving the file name to the latter, I couldn't log in. So the file is still called custom.config.txt (replaced localhost with IP though).
An error has occurred with the Orion website.
System.ArgumentException: An entry with the same key already exists. at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource) at System.Collections.Generic.SortedList`2.Add(TKey key, TValue value) at Orion_Admin_EditDefaultNetObject.OnInit(EventArgs e) at System.Web.UI.Control.InitRecursive(Control namingContainer) at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Regarding the editing of account limitations This is a known issue with the release of Orion v8.5, which our Development team is currently working on a hotfix for this issue. We will inofrm you immediately once we have a fix for this issue.
If this on the additional web server? You may be able to resolve the KeyNotFoundException by copying the *.Schema files from your main Orion server (in C:\Program Files\Solarwinds\Orion) to the same directory on the extra web server.
We are running one NPM SLX and one polling engine. Web-server resides on the primary server.
SolarWinds solutions are rooted in our deep connection to our user base in the THWACK® online community. More than 150,000 members are here to solve problems, share technology and best practices, and directly contribute to our product development process.
