cancel
Showing results for
Search instead for
Did you mean:
dmatlock
Level 7
Solarwinds and Tripplite UPS
Hello,
I currently have several Tripplite UPS power management backup units installed in our network, most with the WebLX addon card installed that supports HTML 5.  I am finding several of the cards are reporting "Receive Discards", very few but they are reporting the errors.
I have tried several things to get them to play nice with SW:
1.  Updated firmware to latest available on the website (15.5.5)
2. Removed and re-added the cards from SW
3. Resat the card physically.
4.  Did a software reset of the card.
Changed the speed at which it connects to our Cisco switches from Auto to 100 FULL/100 HALF etc.. (cards are only 100 MB).
I am perplexed what to do, some of the unit are going across a VPN tunnel to me, so are local.
Any thoughts would be appreciated, I am ready to just remove the from SW and maybe setup their SMTP warning instead.
Don
Labels (1)
Tags (1)
0 Kudos
ebradford
Level 13
Re: Solarwinds and Tripplite UPS
Hi dmatlock​. Welcome to Thwack.
Your post is in NTA, which is a Netflow forum. It would probably get better response in the NPM forum since this question has nothing to do with NTA. Anyway...
There are a number of UPS topics/threads online here. Maybe some are about APC, but the basic info should be very much similar in manner of approach as Tripplite. The Custom Pollers will have different names, of course. Check this out to get started: Re: Power Control Unit Status APC ups NPM 12.4
Check this out for TrippLite specific MIBs:TrippLite UPS Systems
Change the file extension to .UnDP before trying to import.
Good info here too: Setting up Universal Device Pollers for UPS
Regards, Eric
0 Kudos
dmatlock
Level 7
Thank you, I have moved the thread.
0 Kudos
ebradford
Level 13
Have you made any progress with your Tripplite needs?
0 Kudos
dmatlock
Level 7
Not as of yet, I contacted Tripplite and they said for the weblx cards the MIBS need to load in a certain order?  So I have asked them for the instructions and will reach out back to Solarwinds customer support to assist.
0 Kudos
