SolarWinds Orion and Monitoring Raid Controller
I am trying to add monitoring of a Dell Raid card based on OID data to a Node page. Using the Universial Device Poller I have added a defined poller but I am not having any luck returning results on the actual node monitoring page.
Dell Raid Controller
OID being used 1.3.6.1.4.1.674.10893.1.1.130.1.1.5
Any thoughts
-Thanks
  • SolarWinds Server & Application Monitor can monitor the full health of your physical servers hardware natively, without the need to create and configure Universal Device Pollers, alerts, etc. It's just a simple checkbox to enable and you're done.
  • @$3000 minimum licence.
  • FormerMember
    0 FormerMember
    Dunno if these are any help:
    arrayDiskNumber - 1.3.6.1.4.1.674.10893.1.20.130.4.1.1
    Instance number of this array disk entry.
    arrayDiskSmartAlertIndication - 1.3.6.1.4.1.674.10893.1.20.130.4.1.31
    Indicated whether the disk has received a predictive failure.
    Possible values:
    1: No - disk has not received a predictive failure alert
    2: Yes - disk has received a predictive failure alert
    arrayDiskState - 1.3.6.1.4.1.674.10893.1.20.130.4.1.4
    The current condition of the array disk.
    Possible states:
    0: Unknown
    1: Ready - Available for use , but no RAID configuration has been assigned.
    2: Failed - Not operational.
    3: Online - Operational. RAID configuration has been assigned.
    4: Offline - The drive is not available to the RAID controller.
    6: Degraded - Refers to a fault-tolerant array/virtual disk that has a failed disk.
    7: Recovering - Refers to state of recovering from bad blocks on disks.
    11: Removed - Indicates that array disk has been removed.
    15: Resynching - Indicates one of the following types of disk operations: Transform Type , Reconfiguration , and Check Consistency.
    24: Rebuild
    25: No Media - CD-ROM or removable disk has no media.
    26: Formatting - In the process of formatting.
    28: Diagnostics - Diagnostics are running.
    34: Predictive failure
    35: Initializing: Applies only to virtual disks on PERC , PERC 2/SC , and PERC 2/DC controllers.
    39: Foreign
    40: Clear
    arrayDiskVendor - 1.3.6.1.4.1.674.10893.1.20.130.4.1.3
    The array disk's manufacturer's name.
