cancel
Showing results for
Search instead for
Did you mean:
Create Post
SNMP requests for Serial Numbers of Cisco Devices
Hi
I am trying to find out how it is possible to display values for a Cisco Host from a specfic table.
The Table is from Cisco ENTITY-MIB
entPhysicalEntry (OID:1.3.6.1.2.1.47.1.1.1.1)
In the end I would like to have a table of the Serial Number associated with this device/host, e.g.
entPhysicalDesc (OID:1.3.6.1.2.1.47.1.1.1.1.2)
entPhysicalName (OID:1.3.6.1.2.1.47.1.1.1.1.7)
entPhysicalModelName (OID:1.3.6.1.2.1.47.1.1.1.1.27)
enyPhysicalSerialNum (OID:1.3.6.1.2.1.47.1.1.1.1.13)
And if possible I would like to filter the results displaying only entries where the serial number is defined.
Any help would be mush appreciated.
Labels (2)
The problem with the above linked report is it only shows 1 Serial Number even if there is a stack of switches.  Is there a report that will show every serial number regardless of stacked or not?
There seems to be posts going back for years on this one question...
0 Kudos
Hi
The Suggestion of lindsey to Show the Serial number of the devices, I can get this workiing without any Problems.
But as mentioned above it only Shows a single Serial number for the device.
I would like to build a table/Report about all items in the device.
0 Kudos
