SNMP v1, v2c, and v3 are not passing credential test for our Cisco Wireless Controller / Access Points. We are currently using ICMP, and need to switch over to SNMP in order for the Solarwinds topology function to work correctly. There is no way to configure the Access Points for SNMP through the controller. I can setup SNMP on the controller itself but cannot get it to the access points. I can go into each Access Point manually, and setup SNMP but when they reboot from whatever, it reverts back. We have an older software version on the controller (6.0.199.0). Does anybody know if the latest software will fix this problem? Thanks in advance!
