Hey all, new to Orion - we recently took it over cold from an acquired company. Appreciate the help.
Main issue right now is cleaning up old alerts. To remove alerts for a server/node that no longer exists, pretty simple, just delete the node.
However, there are a TON of static routes that were removed, or links that were brought down or moved around, on networking gear. What's the easiest way to get the networking gear to update showing current links and routes without the old ones? I found a way to go into each piece of gear and edit ports, but that would take weeks and it sure seems like there would be a simpler way, as networking shouldn't be expected to remove ports or routes from monitoring every time a small change is made.
Thank you!
